It is currently Sun Aug 24, 2025 11:14 pm
 Post subject: Fret tang
PostPosted: Wed Aug 07, 2013 8:08 am
Hi there folks. A friend of mine insisted to give me some fretwire for free. It looks like a very high quality fretwire, but It has a completely smooth tang. My friend said that he tried to use it but it was impossible to sit. He wouldn't know what to do with it. He said he would either give it to me or throw it away. So I take it but I don't know how to use it. Any idea on how to put barbs?
 Post subject: Re: Fret tang
PostPosted: Wed Aug 07, 2013 8:27 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I believe stewmac sells a crimping too. Thats what you would want to use....however I would recommend getting fretwire with barbs on the tang because it will sit better for sure. No matter how good a job you do crimping barb-less tang, you're probably gonna have to glue it down, (which I think might have been the original idea behind the stuff) and its better in general if you can avoid that.
So I'd say get some fretwire that's a more typical, and use that for your builds. Youll have better results in the short term and will be much less likely to find frets popping up later on. As far as the barb-less smooth tang stuff, I would save it. If you ever have to refret an instrument and are struggling to get the frets to seat, you may find that this stuff will be a life saver.
PostPosted: Wed Aug 07, 2013 10:17 am
practice compression fretting?
PostPosted: Wed Aug 07, 2013 10:52 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I believe you dent the tang with blows from a hacking knife much like you do with bar fret wire.
Brian
PostPosted: Thu Aug 08, 2013 9:09 am
First name: Rand
Last Name: Kennedy
State: CO
Sounds like T-bar wire. Kindof expensive stuff that somebody might want to buy. You might want to sell that on ebay and get some real fretwire.
PostPosted: Thu Aug 08, 2013 9:21 am
I've seen it easily done with blows from the corner of a large file.
PostPosted: Mon Aug 12, 2013 1:15 pm
I'd like to see fretwire without barbs, but holes through the tang, instead. I'm real fond of my fretwire crimper.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Mon Aug 12, 2013 2:15 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Check the thickness of the tangs. Are they all the same, or does the thickness vary?
If they're all the same, glue them in.
If they vary, it's probably made for compression fretting.
Users browsing this forum: Bob_H, Facebook [Bot] and 25 guests
